Turbo removal?
leem2209
Hey All...
Driving my 2007 2.0 D4D home last night I went to overtake a slow driver and suddenly lost power... and became the slowest driver on the road!
Stopped pulled over, restarted engine etc and there's no engine warning lights. Car still drives but a severe lack of power.
Today I did some checks and noticed the pipe from air filter box to turbo was loose at the turbo end. Removed the pipe and saw a piece of rubber stuck in the turbo indeed... looked like a piece of rubber that was used to make the air pipe fit the turbo worked loose and got sucked in.
Pulled the loose piece out and had a good feel round. I can feel another piece in there well and truly lodged. Damn...
so it looks like I need to remove the turbo, which seems a Pig of a job!
Any advice or tips to help?
Im reasonably able to do some mechanical work but no access to ramps or removing engine!
Plus... hope the turbo isn't damaged... 😕
Thanks for any advice.
BUMP! Well tonight I'm having a go! Garage aren't interested in doin the job!
