EV Mode indicator question
Steve Whits
Another question from a new owner please.
When I am driving I see that at times the green EV indicator lights up in conjunction with the indicator that tell me the Battery is charging or powering the car and at other times the green EV indicator is not illuminated but the indicator still shows the Battery is charging or powering the car.  Can someone please explain what the difference is?
I suspect in the first instance you are driving without the engine running and therefore in EV mode in the second instance you are running on Battery but the engine is running to provide a charge and therefore not in EV mode
