Damaged Turbo - part number?
leem2209
After my car losing power and doing a few checks, I found my turbo intake hose loose and a piece of rubber stuck in the turbo inlet. Looks like the rubber was from the end of the plastic hose where it attaches to the turbo.
After failing to completely pull it out I decided to tackle the job of removing the turbo... couldn't remove the whole thing but I did manage to remove the cartridge in situ. Pig of a job but hey...
Dismantled the cartridge and there's this tiny piece of rubber jamming the whole thing. It all seems quite good, bearings are sound, but the tips of the blades are damaged.
Just searching for a spare cartridge, but I've not seen my turbo part number to ensure the spare matches. Any ideas where I'll find the prt number?
20663739_10214299396061498_4602792098855
Edited by leem2209
Spelling
There is usually a tag on the housing, however if you contact Melett they may be able to help since they manufacture cartridges: http://www.melett.com/
Also try toyodiy parts reference fill in ur details of the car and u will find it there.or simply type into eBay should get a hit there
