OBD1 Flash codes and what they referance
AV3
Hello
I have a few OBD flash codes I have pulled from my 2000 Avensis using the jumper method.  They are 23, 31 and 34. Using the internet I have found a list that says the codes relate to the following items.
23 Intake Air Temperature Sensor signal.
31 Air Flow Meter signal (Vacuum Sensor signal).
34 Turbocharger Pressure signal.
Could someone be so kind as to confirm I have the correctly identified componants.
Thank you for your time
The codes  agree with the old lists I have.
