New anti roll bar knocking
Joregan75
Hi All
Two weeks ago I had a new anti roll bar fitted on the front of my 2009 avensis tr t27 , yesterday when I was driving over rough ground I heard a metallic knocking sound coming from the area where it was fitted . It's not very bad but this noise was not there before my mechanic fitted the new part . I have felt around the area and nothing felt loose , so can't figure it out . Could this be normal if a non Toyota anti roll bar is fitted ? Or could there be any other reason ? . My mechanic is on two weeks hols so can't get him to check it out .
Tjek the nuts at the top on the front suspension, common problem at the first T27
Sendt fra min SM-G920F med Tapatalk
The nuts at either end of the anti roll bar ??
