2008 bluetooth or aux audio upgrade
kafkaesque
Hi.
Got a 2008 Rav4 XTR. It has a 6 CD changer. bluetooth works for calls, but not music. Want the simplest/cheapest method of connecting up either an aux port or bluetooth from my phone. See picture. Any help gratefully received. Am in the UK. Thanks.
The single review for that item gives it a '1 star'.
Think most options use the CD changer socket on the head unit - so you may need to decide whether or not you wish to keep the CD changer.
Could look at either Connects2 or Xcarlink.
Could also look at Konrad's guide -
Noticed the review. Not bothered about losing the CD changer. Just confused by all the options etc.
I just posted a reply to someone who wanted some similar:-
If the CD changer is external and connected via the CD changer port, you will need the following -  http://www.ebay.co.uk/itm/Y-Adapter-Cable-Distributor-Toyota-6-6-Pin-Radio-MP3-CD-changer-Yatour-DMC-/401237894618?epid=1967525867&hash=item5d6ba465da:g:XEYAAOSw1S9Wb-s3
The you can plug is any adapter.
  • 6 years later...
Hello, i have rav 4 2008, it have bluetooth, it name is fb122_some numbers, but i dont have code to pair with it... 0000 and 1234 dont work.
