Big Vibrations
TOYMOTA
For some reason when I put my foot to the floor at 80mph the steering wheel and dash vibrate like mad. If I take my foot off the gas it stops.
I had the tracking done a couple of weeks ago but that didn't cure it.
If it's the wheel balancing then surely it would still do it even if I took my foot off the gas, wouldn't it?? :help:
Any suggestions guy's???
Cheers
Jake
hey, another vibrating corolla.Could be many things,
Knackered tire wall
Balance
Buckled wheel
Bearings
Pressure difference in opposing tires/incorrect pressure
Knackered shocks
Driveshaft problem
CV joint problem
many other possibilities
That said, I had mine in Mr T's at the weekend and they cant find the cause of my vibration, bizarre to as it comes and goes.
Hope this helps and you get it sorted
Knackered tire wall
Balance
Buckled wheel
Bearings
Knackered shocks
Driveshaft problem
CV joint problem
Cheers for the suggestions :thumbsup:
New tyres 1 month ago.
Wheel's aren't buckled.
Bearing tend to make a droning noise don't they?
Pressures perfect on all corners.
New springs last summer, although the shox were second hand. (MOT)
Two new CV joints last summer too.(MOT)
Puzzling!!!! :ffs:
Will try the cheapest first I think. Wheel balance!!
wheel balancing is first you should check always...i had like that in my mom escort..when i hit 80km/h...wheeling steers started to shake
I kinda assumed that the balancing would be okay as I only had the new tyres and balancing done just over a month ago. I didn't ask the mechanic whether one of the weights had fallen off but one must of!!
Still my trcking was miles out as well but had that done last weekend and didn't solve it so went for the balancing second!
Will check the balancing first if it happens again! :thumbsup:
if not that case...
maybe this also can be a problem....
1) Engine/Gearbox mounting broken.
2) Driveshaft problem..
regards,
