Engine warning light on after head gasket changed
thechod
Hi
on an avensis verso vvti gls 53 plate (2 litre petrol automatic)
after changing head gasket engine warning light is on constant and when accelerating it flashes
seems to drive well but maybe a little more vibration through steering wheel at idle
what could be the cause?
Talk to the person that changed the headgasket. And read out the error codes is first step...
Sendt fra min SM-G920F med Tapatalk
in process of getting error codes .
well it seems i have air fuel ratio error codes on  both banks, sensor 1's and had one for misfire on cylinder 4
so 2 new a/f sensors and one new coil pack
while im here,
do i have to ever chainge the timing chain
 or
how often do i have to inspect it
would i inspect it via listening or opening cylinder head
and how often to change automatic gearbox oil
