Toyota Mark X Zio front door card removal (door trim panel)
There are 3 screws to remove:
- one at the bottom of the grab handle,
- one behind the removable panel behind the door handle (pull out with hooked piece of wire or bicycle spoke with handle open)
- one accessed by removing the power window switch panel (lever this straight up to avoid breaking plastic lug clips).
Door trim panel then can be pulled away from the bottom and sides as normal, and lifted off the top lip.
See photos.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
