Help with camshaft pully position for timing belt change!
Rickz23
Would be great if someone could help me out in regards to positioning for my camshaft pullys after my timing belt went pop.
In process of doing oil and water pump need some guidance on positioning for the pullys
Thanks in advance, Rick!
Which car is it Rick
Sent from my A0001 using Tapatalk
Take off your rocker cover and on your camshaft at the rear of the cam pulley there is a notch that lines up with a notch on the casting this denotes Tdc for your cams
Hi baz sorry for late reply, I've got a st182 I've managed to find some infomation about it and that sounds about right!
Just waiting on a belt tensioner now as mine was sneezed completely outwards.
Thanks for responding much appreciated, Rick.
