1az fse sub frame
margoram77
The subframes are quite rusty on my car. Anyone know if the 2.0/2.2 diesel cd/ad ftv subframes are compatible with 2.0 petrol. Diesel ones on eBay no petrol. Just in case they start to crumble when i try cleaning them
Have a look at these links. The only difference is the engine support bar. The first is for the 2l petrol, second for the 2l AD diesel.
http://www.japan-parts.eu/toyota/eu/2003/avensis/azt250r-awmehw/3_273550_024_223W/body/5102_suspension-crossmember-under-cover/1#51204A
http://www.japan-parts.eu/toyota/eu/2006/avensis/adt250r-awfeyw/3_273550_138_352W/body/5102_suspension-crossmember-under-cover/1#51204A
Apart from the engine support which has an extra vibration damper bolted to it, the main crossmember subframe looks identical.
That site looks like its goin to be a lot of help. Yeah does look identical, also has the same part number. Sweet cheers
