EGR Valve
TAuris
I had a go trying to remove the EGR valve, I was unable to remove one of the nut which is buried deep and there wasn't any space to get a socket or spanner (stud is too long). The manifold has to come off which is a ***** take.
Maybe you could use something like:
Wynns EGR3 Cleaner
It just sprays into the air intake, whilst the engine is running, to clean the EGR valve. Ok, it might not be as effective as taking the EGR valve off to clean, but it would save you the hassle you're having at the moment. Plus, if you did it once a month, then it would keep the air intake system clean.
