Yaris TR 5dr 1.33 VVT-i Multidrive S
deltarom
Hi
I bought a second hand 2013 Yaris TR 5dr 1.33 VVT-i Multidrive S. In the multimedia system I can see an option for navigation but when I select that option it is showing System not installed. Is that mean Map not installed? or do I need a separate unit for navigation. If so how much will be the price. which device do I have to look for. Thanks
Sat nav was a separate module that could be installed at additional cost. It isn't just the mapping that isn't there.
Thank you for your reply. Is there any chance to know the part no. or could you please tell me is that the same one that I attached.1zb4a45.jpg
Think the multimedia system you have will be the Toyota Touch unit, and the sat nav module will be the 'Go' module.
Different to the system you have pictured.
Be aware that the later Toyota Touch 2 Go module may not be compatible with the earlier Toyota Touch system.
Might be cheaper to replace the complete multimedia unit with a second hand Touch with Go or Touch 2 with Go.
Have you priced the updates for the Touch with Go/Touch 2 with Go - as they may be more expensive than buying a TomTom, Garmin or similar.
This is the system that I have
Is new system compatible? I mean Touch 2 with go. This one is Touch with go (need module for nav)
Here is what you need : https://www.toyota-tech.eu/aimuploads/{32348A0F-FC7E-DE46-0D5A-52AB12FFFC7E}/Yaris_Touch_and_Go_RHD_PZ490_00331_00_AIM_002_218_2.pdf
You cannot interchange parts from Touch & Touch 2, Touch 2 can be fitted but it requires modifications to make it work.
Thank you...If I buy toich 2 go will that fit into my car?
Fit yes but you need the harness ends/plugs from the the later touch 2 car and then splice them into your earlier cars harness, it is far from a straight swap
Here the picture showing one touch and go without sat nav and another one is touch and go 2 with sat nav .
If I buy the whole unit touch and go 2 which cable do I have to modify?
Thank you for sending me this pdf document. I bought a second hand navigation module and ordered the cable with part number as explained in the pdf manual. Connected the module into the head unit and it is working perfect. Thank you.
Im just wondering http://www.toyota-tech.eu/aimuploads/4dab23b9-8506-40c3-9214-7cd6748e1284/Yaris_Front_Fog_lamps_RHD_PZ457_B0513_00_AIM 002_723_0.pdf is that the fog light diagram for my yaris.
