no oil light
toppo123
hi all,having a wee problem with my 2007 2.2 d4d rav 4,i have no oil light working on my dash,have replace oil sensor switch and check wiring and try disconnecting the Battery but no joy,is it possible that the led bulb is away in the cluster,i was looking to know if there was a way to check this,thanks
It's normal for warning lamps to light when the ignition is turned on, before the engine is started.  If it does not, the lamp is suspect.
