Fitted a Bosch wiper which works perfect, however it hits the pillar. Any idea what to do?
Mmmmmm, it does look like the wiper's not parking at its lowest point properly. Maybe the whole arm has shifted on the spline, or needs the mechanism adjusting.
I've just tested my Bosch wiper at its highest speed and it doesn't do that!
This is where it parks on my Aygo.
I'll test mine tomorrow and report back but I've got the same wiper on a mk 2 aygo and had no problems. Admittedly I've not had it on the highest speed (partly because its so good at clearing the rain from the windscreen)
Update just popped out and tested it now, mine works fine on all speeds.
As stated by others, just watched your video and before you even move it, that is parked very high up!!!
Just needs adjusting...
Yeah, you must be right, I just watched my wiper arm removal how-to and I can see the arm was parked right below the registration sticker. Now it is above the sticker
wiper arm adjusted, thanks for your time
