Check engine light and fumes smell
Jaxx12
Hi guys
So today my check engine light came on just as I was getting home from work. About 2 hours later I had to take my dad to the airport and on the way we could both smell gas/fumes in the car. Any idea on what could be causing this? Don't think it's a coincidence that the check engine light and gas smell started on the same day.
A side note, I've smelt gas/fumes in my car before but that was only when I had the heater on in the car during winter time. Not sure if it's related at all.
Thanks in advance.
As you leave us to guess the engine size and petrol or diesel, I can only suggest..
Car  not serviced, serviced incorrectly
Blocked air filter.blocked fuel filter,
Failed seals around boot.
Leaking (rusty) fuel filler pipe.
But I am not a clairvoyant.
