T27 Heater/Aircon control malfunction
Leex2017
15 hours ago, Cyker said:
Niiice :thumbsup:
We can add another person to the Successfully Relaxed tally :laugh:
The car was 9 years 51 weeks and 3 days old at the time too, so they certainly honour the ten year warranty!
I have a 2014-2015 avensis 1.8petrol estate t27 I’ve got a 2016 t27 climate control will it fit or do I have to get exact year
  • 1 year later...
On 1/5/2021 at 8:57 AM, yossarian247 said:
It might be worth trying my trick first. Switch the ignition off, then spin the temp control knob repeatedly back and forth really fast with your finger a few times. I had the problem with the temperature control behaving oddly last year, and simply spinning the temp knob seems to have cleared whatever dirt was on the contacts. It has worked fine ever since.
This worked on my 2013 Avensis !!! Thank you. Definitely worth trying.
I suspect it will fit and work, so long as it has the same functions your original has - Auto or non-auto. The connection should be the same.
This will sort it out properly its just all the grease and crud thats built up over the years
just follow the video closely ...switch cleaner and cotton buds job done
Beware you must be competent with dismantling alot of plastics in the right sequence or you might break something ?
Its doable even i managed it 🙄
