Car bottom plastic protection clip. Please help.
TRAvensisember
Hello there. everyone greetings. I have a problem. I could not remove the plastic clip that appears in the picture. I did not turn around clockwise. After dialing, I pulled it down and it never came out again. Any idea how to take it out? Thank you
That looks as though it clips over a threaded stud on the body work. Those type should unscrew anticlockwise with a broad flat tipped screwdriver. Refitting is 'push-fit' as within the clip are one-way rear facing tangs which bite against the thread on the stud.
thanks for the answer. I turned it clockwise, but after a while, it turns to waste. when I was in this state, I did not pull out towards myself again. :(
twist there is another part in the inner part and it comes out with a constant rotation. most of them were broken. I do not know how I can find new eBay, AliExpress, etc. sites. Does anyone know the name?
You will not find any after-market clips like those. The Toyota dealer should be able to supply them.
IF the bodywork posts will accept an m6 nut (normally fit within a 10mm socket) you could use these with a suitably sized washer.
http://www.ebay.co.uk/itm/361338404156
They are also available with a full hex head.
Thank you so much for your help. I will search :)
