Alarm going off at random
IanOfYork
The car alarm has been going off at random for some while. Unlocking the car and relocking it seems to shut it up *most* of the time.
I have checked the windows and the door switches and scanned for small creatures ... but there is no clear reason that I can find.
Any thoughts?
Hi Ian, welcome to TOC :smile:
Can you confirm whether this is for an Avensis (this forum) or a Prius as in your profile? & for whichever it's year?
You seem to have covered the usual bases except that another cause can be a failing Battery (most alarms have voltage drop as a trigger).
Is it a Toyota alarm or an aftermarket like DEFA? I had a similar issue on my old Avensis with a DEFA, turned out to be a bad inline fuse holder. Also, believe it or not, cars parked close to the kitchen can have the alarm set off by the microwave.
Might seem a stupid idea but check there are no insects trapped in the vehicle.
