Yaris 1.0 2002 - Hub nut torque settings + gear oil capacity
TBJ
Please could someone tell me the correct torque settings for the front hub nuts on a 2002 Yaris 1.0?
Also what is the gearbox oil capacity? I have put in 1.9 litres and it seems happy enough but I'm not sure if it's right.
Just rescued a little Yaris from the scrapyard - only needed a new clutch - but I don't have a service manual and don't want to buy one just to find out the above. Thanks :)
Rowan Hi,  do you mean the main axle hub nut?? It's 216 Nm/160 ftlbs.
Hi, I'm not sure which Gearbox you have. If it's Auto it takes 2.9 Ltr or about 5 Pts and check dipstick level when warm. Actuate through all the gears to get fluid circulating.. If it's Manual keep adding until it trickles out of level plug. easy peasy Oops! just realised you changed the clutch Dooh!
