Missing ETCS fuse
forge9
Hi all, i wonder if anyone can shed any light on this but my 2005 ravv4.2 d4d had a engine light come on the other day and went into linp mode with ABS VSC lights on the dashboard lit. After turning engine off for a few minutes it started fine and has been ok ever since. I went to reset the engine light by removing the 20amp and 10 amp ETCS fuse but to my suprise the ETCS fuse was not there. I have had the car since 2008 and I have never been in the fuse box before so either its never had one fitted or its been removed by a mechanic at some point. I could fit a fuse I suppose and see what happens but wonder if anyone knows why the fuse might have been removed. The diagramme inside the fuse box lids indicates a fuse should be fitted so a bit of a puzzle really!
