kblevis
kblevis
Greeting,All.
Is there an easy way to replace the tail light bulbs in the lift gate on my 2013 RAV4? I've managed to get them out but i cannot put them back,owing to the large hand syndrome.The space in the gate is very limited and there is a risk of the holder dropping down inside the gate trim.I'd appreciate any tips on how to do it.Many thanks,kblevis.:sad:
If I am doing something where I might drop it down somewhere I can't reach I find a piece of string useful and then cut it off. Is it possible to just detach enough of the door card to do what you want to if you do not want to remove it. I think it is held on with plastic pins which if you are careful can then be popped back
Del
Greetings,Crofter.Thanks for your answer,it looks like a good idea to move the trim a little.I'll have a go.Regards,kblevis.:biggrin:
