Yaris problem
ngoba
Hi guyz, plc help me, I have a 2005 Toyota yaris, my ploblem is hard starting when the engine is cold, when is parked for approximately 10hours +/- , but when its warm(parked for less than perhaps 5hours) its starts nicely, so I always have problem in the morning, coz I always have to kickstart the car.
Sent from my F3311 using Tapatalk
Petrol or diesel, and what size engine?
1.3, 4cylinder, petrol
Process of elimination I guess...I'd start with Battery condition.?
The Battery condition is perfect because the starter turns the engine thousand times but cannot start, and after I kick start the car and hold my foot on the accelerater until the engine get warm (coz it doesn't idle when cold), threre after if I kill the engine it starts nicely, that proves the Battery is good.
Leak in the fuel system, filling up with air..  When car has started, the air disappears. When left, the leak slowly allows air in.
Check all fuel hose connections under bonnet.. for signs of fuel leakage.. you should smell petrol..
Thanks for ur response but if I may ask, should that cause a car not to start at all or perhaps a delay, reason why im asking is because I crank the engine countless times, wth a promise to start but it doesn't
