Auris T180 2.2 deisel keeps cutting out
Cassie
Hi I've got an Auris 2.2 deisel and it's taking longer to start. It started one morning I was driving and the power went and the dash lights came on. It started again after I Disconected the Battery. A few days later same thing. But was harder to start.Then it happened again yesterday it started after a couple of times then happened again 3 times so disconnected the Battery and it was ok. It will no doubt happen again I'm to nervous to go out in it alone now. Any ideas what could be causing it. Power from Battery is good aswell as alternator. Its push button start
How many miles on it & when last serviced?
has it had any injector or glowplugs changed? You are into the sort of mileage where it could be these. Get it code read in case there are any stored.
No no changes and no codes either it's not everyday either just some days it happens
