Couple of questions - Can you help?
Hi all, I am hoping someone can help. I have had my new C-HR Excel for a month and quite pleased with it, lovely looking and everyone that see's it wants one.
I have two questions:
1. Is there a way to turn up the brightness of the lighting around the cup holder and door storage bit? If yes, how do I do that?
2. I have the Touch 2 system and wanted to know if I have to manually update the maps and software or does it do it automatically via the in-car WIFI? If manually does anyone know how to check if it needs updating and how to do this?
Many thanks in advance
Steve
Hello Steve - welcome to Toyota Owners Club
As regards the brightness of the lighting, this maybe covered in the full owners manual which one can download from My Toyota - https://www.toyota.co.uk/tme#/my-toyota/eManual
Updating maps has to be done manually, it has been covered in other threads but the process is something like...
Got to Toyota site and find shop.
Locate maps which might have a price against them!
Add map to basket and price should become zero
Download to local drive - do not download to memory stick (this took me a long time)
Extract map files to memory stick - there seems to be no option to just extract the files you want so you have to get all of Europe as individual countries which was also slow
Turn on car and put memory stick in USB port - need to be in ready mode not accessory to prevent power off while loading maps
System should see that map upgrade is available from USB and allow you to select individual countries to install - strongly suggest you make a selection rather than the default all
Turn radio on and wait for maps to install - this took me a long time even with just UK maps selected
