any1 no where I can get Speakers for my e12. looking for 2 front ones. I'm looking for original ones like factory ones. anyone no where I can get them?
Here is a suggestion. I installed 165mm (6.5") JBL 2 way Speakers in my old Avensis, a few years back. They were installed behind the standard door cards and grills, so you would never know they were different. I made my own adapters, but you can buy them for your car or even source secondhand Speakers. This is just an example of what is available. https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=Corolla+E12+speakers&_sacat=0
It will be hard to get Speakers in good order and you will need to go to car breakers.
i actually have 6.5s baught but didn't no about the adapters. how are they held to the adapter do u no?
You normally use pop rivets to fit the adapters to the door.
This place has a good selection of adapters etc.
http://www.caraudiodirect.co.uk/install-adaptors?cat=600
Its well worth using some Dynamat or bitumen panels on the doors, plenty of ytubes on doing that, though doing the full door is a bit overkill, around the speaker and just behind the speaker on the outer panel is key.
