Hi can anyone tell me if the rear hatch from a 5 door Carolla with fit onto a 3 door Carolla my 3 door hatch is damaged and need to replace it
My Carolla is a 2005 Model
I'm not a professional mechanic, but it looks like the hatch is the same on the 5-door and 3-door E12. If you look at a 3-door 2005 models back door panel and glass: http://japan-parts.eu/toyota/eu/2005/corolla-hb-ukp/zze120l-dgmdkw/3_153550_011_/body/6708_back-door-panel-glass/2 you will see that the part number is 67005-02060. If you look up that number on http://www.toyodiy.com/parts/xref?s=67005-02060&mE=on you will see that there are both 3-door and 5-door cars in the list of cars that use that part. If you want to make sure, you can enter the VIN for both cars in http://www.toyodiy.com/parts/q.html and then navigate to Body > Back Door Panel & Glass to check that the part number is the same for both cars.
