Injectors values
Pyroman
Hello again!
Can some smarter explain to me shortly, what mean this values and wich injectors real bad.
With minus is bad?
And differences too big too?
Engine is 2.0 d4d 85kw 1cd-ftv
Engine warm and running idle.
And here is diagnostic results:
Revised Injection Volume#1    -2.498    mm3
Revised Injection Volume#2     5.004    mm3
Revised Injection Volume#3    -2.342    mm3
Revised Injection Volume#4    -0.622    mm3
Engine starting not very good, but ok, want longer keep starter running.
Glowplugs replaced with relay, but still glowplug light showing 2-3 sec only. No matter how cold weather is. MAF sensor maybe?
No engine fault light in dashboard too.
No any faultcode too.
Checked with Toyota Techstream
Thank you!
P.S. Sorry for bad english ;)
+ or - 3.00 is within spec so injector # 2 is faulty @ 5.00
i was told by toyota  tech the other day that "3 " is  "gone" as he said as i have 2 at zero 1 at 2.3 and 1 at 3.65
