check parking brake and VSC
airt
Any help to get these warning lights to stay off it is showing code C1201 and after clearing them about a week and then they are back again.Any help please.
C1201 Is a generic code indicating that there is a fault code set and that communication between the engine ecu, vsc ecu and parking brake has been disabled until the fault is corrected there will be another code stored in the car indicating a fault stored in one of the ECU's mentioned.You may need a more specialised code reader is the reader being used is only seeing C1201
1 hour ago, airt said:
yes he was using a Snap on reader,thanks for the help.
I spoke to my auto electrician friend who does not rate Snap-On. When he did diagnostics on my car for EBP related issue, the device he used tracked down the fault to a disconnected sensor, and the actual sensor by name and location. He could not remember which of the diagnostics he was using, since he carries a few and he was working on another car at the same time as mine.
