Help please-flat battery change
saxo265
Just come to start it after 2weeks and flat. It's the original 2009 Battery T180 spirit D-cat. Trying to locate a new one, if I can get one locally do I need to do anything special to replace it or just unbolt it and remove and replace? never done one before on a modern car! Any help will be appreciated thanks as I am away from home and due to return tomorrow!!!
Go on to eurocarparts website put in reg of car and will give you the right Battery.you could of course check the number on the old Battery.also euro car parts normally do a sale.just unbolt the Battery put new 1 in.you will have to reset windows by putting them down then pull up and keep fingers on button until they are fully up and hold for a second or 2.and then reset radio station.
Many thanks Frank, had to get one from Halfords (Yuasa silver 85 - 800A) sadly I was away & had to get one quickly so unable to shop around, did find one £50 cheaper but could not go and get it!!! all in ok and everything now working apart from windows which I did not know that bit so will go and check and sort.
Thanks again :thumbup:
