Background light fuse
Silvero
Hello!
I have a 2005 Toyota Avensis. Where is the fuse for the radio and climate control background lights? I think I accidentally broke the fuse when changing the light of the gear lever. When I tried it, all the lights in the radio and climate control buttons went dark.
I couldn't find the right fuse from the user's manual. I pulled out and checked a couple of fuses, bus they seemed fine.
I would be very thankful if somebody tell me which fuse to change.
P.S. Sorry about my bad choice of words. English is not my mother language.
It's probably not that people are unwilling but that they are unable to because they don't know either.
Is it possible that the fuses are actually in the units themselves?
All four fuses related to illumination circuit.
1st fusebox is left of steering wheel, below mirror adjustment switches
2nd box is right above pedals.
Illumination1.thumb.png.9a84302b4fa13066e34fe368c3d1b9f5.pngIllumination2.thumb.png.16423c6af16eec2cf5097257fe1a784f.png
  • Thanks 2
Thank you, Ents! I will try to locate these fuses on the weekend. If I'll find a solution for my problem, I will post a response here in case somebody else will experience same kind of troubles.
  • 2 months later...
Problem solved and background lights are working again. The 7,5 A fuse was blown.
