About CD Changer
Haitham Mohamed
I have Toyota Avensis 2008 the car radio doesn't contain AUX Or USB so I find on the internet that I can plug cd changer to make this extension to my Radio so I found Moonet CD Changer with 6+6 pins and I find the socket available to my radio my Model Radio is Toyota W58830 but the description mentioned only the W58831 I searched on the internet between them I found there's no difference between them except the skin of the radio the W58830 Is black while W58831 Is silver I Would like to Know that may be there's difference between W58830 and W58831 Except the skin of the radio and there is a photo illustrate the difference
Hi I found a cd changer adapter on eBay for 36pound. It has usb micro sd and aux. I havent tried it yet but I read it works perfectly, also you can control from steering wheel.
Have a look on this title: Car Stereo USB SD AUX MP3 WMA CD Changer Adapter TOYOTA Auris Avensis Corolla
The Yatour adaptor does not list the w58830 either. I would imagine that it will work but try emailing the vendor first. They will probably be happy to supply the unit and offer you a refund if it doesn't work with your head unit.
http://www.ycarlink.com/pd_10512_USB-Car-Stereo-Adapter-MP3-AUX-Bluetooth-interface-CD-Changer-for-Toyota-Lexus-Scion-Small-6-6-plug-2003-2013.htm
Most Avensis with 6+6 CD changer socket will work apart from some with the nav screens, but apparently a couple of companies know this and have a different wired cable for the USB adapter. When I bought my adapter, the model I used was listed for Avensis from 2003 to 2008 (T25 models). My car is the later T27, and the unit works fine.
