Does any one known were to find the OBDII socket on this model. This model was imported into NZ recently.
Had every plastic detachable removed, glove box, ashtray etc. Still unable to find it.
The Raum is based on the Toyota Vitz (Yaris) rather than the Corolla.
On a standard uk 2006 corolla and some models/ cars  I have come across,  the socket is located just under the dash board, above the gas pedal.
A google also shows some Toyotas have a covered Diagnostic socket in the engine bay near the front strut mounting.
Thanks for your help, Found it directly under the steering wheel, way back. Trick for young players.
