Toyota avensis d4d 2.2 litre injector driver too hot cranking bt not starting
Tabeel Raphel
My Toyota avensis d4d 2006 was replaced head gasket on a local garage after that the injector ecu is so hot when the key is on cranking bt not starting at lt short circuit injectors number 3 we removed it and replaced it still the same problem.No error codes .What might be the problem
Edited by Tabeel Raphel
Adding another information
