I cannot install Cyclops
quanghieuci
I've just bought a 3-year bundle of map upgrades and apps for my '14 Auris Hybrid I find I cannot install Cyclops or if it did install, it is hiding somewhere as I can find no reference to it on the satnav. I know others on the Toyota forums have had the same problem in the past but nothing suggested seems to work. The car came with Coyote installed but that expires shortly and at £70 seems expensive . I assume Cyclops does much the same job. Does anyone have any idea if there is an answer? Thanks
Do you need to edit your profile to include the Auris, as it is showing you have an Aygo.
