SRS warning light on dash.
Assistance required please, SRS warning light previously came on intermittently now permanently on.
Does anyone have a wiring diagram showing the colour of wire(s) and where they are attached under the seats ?
After checking, by pulling/pushing various under seat wiring connections I think I have found the cause. Under drivers seat towards seat belt stalk there is a block secured by small screws. (See photo) The wiring to this switch is 2 wires, yellow (connected) and a reddish one (not connected), where the yellow one is attached to the block it looks like another connection next to it. Should the reddish wire be attached here ? If yes then how should I re-attach the wire ? Can I remove the small block, will there be sufficient room?
6D2E7C49-6EC5-4E28-87C9-1270146889F3.thumb.jpeg.3d9586f688c2357dfda09c16741b297a.jpegWill be grateful for any help/ replies.
Hi, just an update. Tried Toyota Parts Dept. confirmed the connecting block under drivers seat is only available as part of the wiring loom, will be a back order and £610:02 + vat !
will try an Auto Electician who reckons it will take a couple of hours to fix and also test/analyse to see if any other faults.
Further update: all fixed!
local Auto Electrician repaired and checked system in 2 hours.
