Avensis 2011 outside temperature sensor
tervajorkki@gmail.com
Outside temperature sensor wiring is done of "Fiat type" cabling, and it will wiggle broken near the sensor unit. The fault location can be found by first removing the sensor from the bracket and lifting it up until you see the broken wires, they look like "straight-angled". Sensor wire metal is too hard, so it will wear until broken, then the display will show incorrect values or just negative values.
