Hi [emoji5]
New to the forum, not long purchased a Corolla T Sport and needs quite a bit of work. Car doesn't feel stable when at higher speeds, feels like the car sways or doesn't feel level it's really hard to explain. Wheel bearings are shocked, had one replaced but other one making a horrible noise not sure if this is linked??
Other issues are cat c damage and was bodged so ideally new front bumper and new headlights.
New radiator needed and suspect leaking water pump.
I have the common seat problem where they don't move back and forth [emoji17].
Wishbones corroded and one has a crack.
Clutch is slipping slightly.
Suspect broken window motor, for some reason I can't open my door when window motor stops nearly all the way down [emoji53] [emoji23]
-Ant051bc9bbbba7a43dbbc795420f80fc8e.jpg&key=1970138e61d8070818eb336d703f1aeb68022475b87552d1c50199f966f84abbb62dbcee5bfa136216ff65759cb29d78.jpg&key=65f558bd6f97820bf75c42c777dd93148614317e920736a6b94c7804cf51b5b048e953cea15c87ca8066cf0a40033a10.jpg&key=072e2cb77ea8d70be1faa4f76afaf28ecd9bf051bdf5bd28a1e8c42c43d09629a9dd1c30d320f174a7bbd35037ccd067.jpg&key=f6575a0b2981b4f963bab0243ff03d8a684b4802b46de3e2d4d18b751e3274d9f9e46010ee3cd468b77ffc14c4bdc2ba.jpg&key=3b31b776719322784109082d2132c0c85e59fbcdd596e9c8ff63597b525b3ae8
Sent from my SM-G955F using Tapatalk
Ordered some Hardrace wishbones [emoji102] [emoji7] as my current wishbones are a little worse for wear and have a crack. I don't think this will fix the issue I described though [emoji17]de8456726af0c7c3e51539a052a5a6c5.jpg&key=ba67a1882e348d0eb7dd746deff2a3f66303f8210450aebc695085b55d94a2c7f559a7b47a5bf1af0224b3e34a0396aa.jpg&key=4e46019273d849df744ce03a724394e4f8fdaaff82de489b8a88c52dabaac775606fa83dcf16dbd767acfa3dfb2cff2e.jpg&key=c60e66cf6ba0c56f639eceb0b77055ea175125840c72b300b3d0cc76bfe40652
-Ant
Was looking at a new set of alloys but not sure whether to go 17s straight fit 4x100 or go with the 18s as they have the colour i want but that will require a hub adapter / spacers.
Would 18s be a disadvantage and worth just getting the 17s resprayed or worth going 18s?
PFA [emoji6]
Thanks [emoji106]
- Ant
That’s a good looking wheel mate. I’d personally go 17’s for best handling. But if it’s more show car 18’s. I’ve heard it messes with the speedo though. Not sure how much to be honest buddy
Yeah I would be happy with 17s mate but not sure if it will have the same look as that picture and they only do the 17s in black and silver [emoji17]
In a right pickle I want to keep the speedo close as to be honest.
-qnt
Got a new wheel bearing from Euro Car Parts, anybody used the q-drive bearings before? Also got an oil filter to add to the service list and a little sticker why not [emoji102]
Cars going in at the end of the month to have the bearing done and have the wishbones fitter and also the auxillery belt replaced as it is soon to go! [emoji44]
-Ant
Those wishbones look nice.
I hope you don't stretch the tyres, that drives me absolutely bonkers!
Are the ones on the picture I posted stretched? :sad:
Yes, very!
Just now, saxo265 said:
Yes, very!
:sad: thats a shame then.they look nice
I can't see those wishbones on the Hardrace site. Where did you get them from?
Andy.
Andy.
I got them from gt4-play.co.uk, they don't come with ball joints but getting them from Toyota next week [emoji102].
-Ant
Cheers Ant. I will have a look at them.
Andy.
