sensors
deano20010
Ok so got a check light checked and gave off these codes
P0115= Engine Coolant Temperature Sensor Circuit Malfunction
P1135=  Heater Circuit Malfunction Bank 1 Sensor 1
P1155= Heater Circuit Malfunction Bank 2 Sensor 1
The bloke at garage told me to get new P0115 Coolant Temperature Sensor and it should fix the other error codes is that true or do I need to replace all sensors
Probably true.  It often happens that a fault in one area gives false alarms in others.  It's very unlikely that both heaters went wrong at the same time.
Before changing the CTS, try cleaning the contacts - could just be a poor connection.
