auris timing chain replacement
t mcguire
at what miles are you to replace timing chain or tensioners on a 65 plate auris estate with 66,000 on the clock...many thanks in advance
Moved to the Auris club.
timing chains are normally for the life of the car
unless they create a loud rattling noise.
I would be concentrating on changing the oil at least every 10,000 miles. This will help protect the engine internals, including the chain and tensioner. This car would be coming up to it's 7th oil change!
