Driver side electric window out of mooring
davemere
Hi there. Yesterday, my driver side window seemed to pop out of the mooring. The electric motor works fine, the window will wind halfway up and then it seems to come loose, directs into the car, then the motor reverses and carries it back down. It's obviously not attached properly.
I understand that remounting isn't a massive job, so happy to give it a go. Would really appreciate some advice on how to approach this job?
big thanks in advance - Dave
Take off the door card look for the screw locations once off there is a plastic sheet you might need to cut it if you can' ease it off if cutting just tape up with duct tape....with the window down check to see where it' popping out of the "mooring as you call it" it's probably tell rubber twisted.
