Interior light and Cubbybox arm rest finshed
Ford Prefect
Very nice, Can you give details on what parts you used, and how you did it ?
On 05/12/2017 at 8:17 AM, craggle said:
Looks good
Is the arm rest home made or a purchased item?
Craig.
H Craig, and sorry for late reply (Notifications prob)
Got it off eBay, there are loads of these particular one's
This was the only type I could find to fit my install....You have to remove inner seat levers and this has to be mounted Dead centre between the stubs, which are Not dead centre to the chassis 'bump'.... it does foul them slightly.... But needs must.
https://www.ebay.co.uk/itm/Carbon-Armrest-Centre-Console-Black-Faux-Leather-Universal-Car-Van-Padded/272233636219?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Hi Matthew and sorry for late reply (Notifications prob)
The most difficult was finding a way to secure this lot to the floor as I did not want to risk going thru the tank
by drilling holes for Rivnuts... So I came up with the idea of bolting the safe to a strap which goes under the seat rails
(Very F Fiddly!) But measured up for the strap profile 5-6 times and it dropped in like an OEM part first go!
Safe (out of stock with this seller)
https://www.ebay.co.uk/itm/Digital-Steel-Safe-Security-Electronic-Key-Lock-Home-Office-Money-Safety-Box-UK/202058363261?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Dimensions
Style:    Black Key Lock 23*17*17cm
Quantity:
Price:    £17.99
Strap B&Q
http://www.diy.com/departments/steel-panel-l-1m-w-40mm-t-2mm/254559_BQ.prd
I like your thinking for fixing it down, very good :thumbsup:
18 hours ago, Motomatt said:
Thank you :smile:
Your very welcome Matthew!
I have a question, I need to bring a feed from the Battery thru the firewall/bulkhead....can you suggest
a point of entry that is easy to access from inside? I want to put a power socket on the dash some where...
Cheers Mark! I thought I could get away with (carefully) drilling thru the floor pan, but
going thru the top of the tank would have been such a pain to put right! Ha Ha!
That bracket stretched my head I can tell you! :ranting:
I have a question, I need to bring a feed from the battery thru the firewall/bulkhead....can you suggest
https://photos.app.goo.gl/xBsKbiaSJnW4YwRP2
This on the drivers side near steering column
There is also a grommet on the passenger side just below the plenum chamber.
Have a look in THIS THREAD
