o2 bank-1 sensor-1 location
kjedyp
Hi
I have fault code P2237 on my Avensis T25 2007 2.0 diesel.
Does anyone know where the location of this sensor is? Maybe a drawing ?
cheers! :D
This is only a guess, but this may be what you are after -  http://www.japan-parts.eu/toyota/eu/2007/avensis/adt250l-alfnyw/3_273550_131_352W/electrical/8401_switch-relay-computer#89467B
In the same diagram there are two other sensors 89425/89425A for exhaust gas temperature, but the one highlighted 89467 air/fuel ratio should be the one.
  • 3 years later...
How did you solve the p2237 problem? was it a bad sensor or something else?
Got the same code now on my avensis.
