T25 rear fog light missing
Pyroman
Hey! It`s me again!
Rear fog light lost. Changing lightbulb and fuse just in case (old bulb and fuse looks ok, but just in case), but still nothing!
In dashboard indicator light on, but that is all.
Front fog lights working ok.
Now i think, maybe relay not working, but cant find were is located?
Anyone?
Thank yo!
Do you have a tow bar fitted as the electric socket for the tow bar usually contains a switch to disable the cars rear fog light when a trailer is fitted and the small switch is the socket is common for failing.
Hmm.....yes, i have tow bar. But never heard about switch.
Thats located on connector inside, mounted on car probably?
Thank You for new idea! ;)
Special tnx to Devon Aygo!
You have right! This connector was rusty and looks very bad.
I change connector with new and after 3.75 euro and 40 minutes left in garage, all working nice!
Tnx mate!
  • 1 year later...
I have the same problem now. Where exactly is the small switch located?
What did you change pyroman?
  • 2 years later...
Doesn't make sense to me. What would be the idea of that extra switch? If you don't want to use the rear fog light because you have a trailer, you just don't switch it on from its own switch (in steering column)...
However if you did want/need the rear fog light on then without the kill switch the car would light up your trailer/caravan affecting your rear view hence the switch which is located in the trailer socket
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
