02 Avensis Brake Servo
Skevy44
I'm trying to help fix a friends Toyota Avensis. The brake servo has gone and I'm having a tough time finding a replacement servo from a breakers yard. The Part Number i have on the servo is 44610-05110, does anyone know of other parts that are compatible?
My knowledge of Toyotas are very limited as I mainly work on German or Italian cars.  So any help people can give would be much appreciated.
I checked on ToyoDIY and Japan Parts EU. Every T22 Mk1 from 1997 - 2002, used the same part regardless of the engine type and size - petrol, diesel, capacity, leanburn, vvti, etc.
http://www.japan-parts.eu/?parttt=&part=Part+44610-05110+(BOOSTER+ASSY%2C+BRAKE) was+found+on+the+following+models%3A++Date+range Model Frames%2FOptions Found+in+diagram+10%2F1997-12%2F2002 TOYOTA+AVENSIS AT22*%2CAZT220%2CCDT220%2CCT220%2CST220%2CZZT22* 47-03%3A+BRAKE+BOOSTER+%26+VACUUM+TUBE&regi=EU&cars=ok
So you only need to find an Avensis Mk1.
