Car alarm
Dan spice
I have a toyota avensis 06 for some strange reason the alarm comes on every morni g and i cant turn it off no matter what i could do and i dont no why its started doing it for
Hi Daniel, welcome to TOC :smile:
How old/what condition is the Battery in? Most alarms have a voltage drop sensor & these cold mornings take it out of old/poor batteries.
as an alternative if you lock the doors using the mechanical key it won't set the alarm.
Would you recomend a new Battery then and the red light on the dash to show its its lock is constantly flashing aswell
Do you know how old the Battery is/can you get it tested?
Forgot to reply to your bit about not being able to get the alarm to turn off - it should silence when you start the engine.
