Check Hybrid System
abbasshiraz
Hi all,
my toyota auris hybrid 2014 with 102000 mileage, it suddenly come up with (Check Hybrid System) on dashbourd folowing with engine and the triangle light on. it stoped and went into the limp mode.
i called the AA and they found this error codes when diagnosed the car. (Patrol found the following fault code/s:System : Hybrid control - 1UH / Hybrid control 3.0P0A40 - Rotor position sensor 2. Error Message : Faulty.P0A41 - Rotor position sensor 2. Error Message : Signal too low.) so we took it to Toyota . the car has no warranty as it just passed the 100K. so toyota says they dont know what could be the issue!!  they want to diagnose the car for 4 hours which will cost more that £400 before they can tell me what is wrong with it. they also said it could cost more tan 3 or 4 thousand pounds.
Has anyone had the same issue or any help and suggestions would be appriciated.
Have you been getting it serviced at a Toyota dealer to schedule?
If so, my understanding is that you should have been getting a Hybrid Health Check as part of that & that should extend the warranty on the hybrid system by 10,000 miles with no upper limit on total mileage?
The hybrid health check checks the hybrid system is operating effectively, and provides a hybrid Battery warranty extension rather than a warranty extension on the hybrid system.
