Techstream Brake Bleed On 1.6 D4D
Toyota_UK1
Hi All
Does anyone here have experience in using Techstream V12 to bleed brakes? I have successfully communicated with the ABS/VSC/TRAC ECU but I don't get the "Air Bleeding" option showing in the utility menu. Does this mean it is not required on this variant auris?
This is regarding 2015 1.6 D4D (1WW Engine)
Any help is appreciated
Thanks in advance
Techstream is only required to bleed the brakes in the Hybrid models not conventional engine models
Hi Lee
Thanks for clarifying, I have one one more question which I can't find any information on.
If the start stop Battery on the same vehicle is replaced with a new one, will it need to be configured or registered to the ECU or is it just a matter of swapping them out?
Thanks again
