Scraping noise
KJNEAL
I have an intermittent noise that sounds like the disc rubbing, it happens when in motion and sometimes when at stop. As I said it is intermittent and therefore has proved difficult to pin down (it has been to my local garage, reluctant to take it to main dealer at £100+/hour). When it occurs when I have parked it stops when the ignition is turned off. Although it is not a constant noise it is driving me mad ---- HELP !
If it occurs at a standstill, then it can't be a brake disc rubbing. Look in the area of the cabin fan or coolant fan. Also, when you hear it, try pushing the clutch down, see if the noise stops.
