Tail light is out
angelhippy
Halo Everyone...
I have a 54 plate Avensis and the rear light is out... Changed the bulb which was  black but it is dosn't work... I think it could be the wire as the other lights on that side work fine. How can I fix it? MOT duye in a few days. Also my boot won't stay open. Its very heavy when lifting it ! Is there anything I can do to fix it ?
Thank you in advance.
Hello Amanda - welcome to Toyota Owners Club.
Shouting removed - capitals count as shouting.
Moved to the Avensis club
8 minutes ago, angelhippy said:
HALO EVERYONE...
I HAVE A 54 PLATE AVENSIS AND THE REAR LIGHT IS OUT... CHANGED THE BULB WHICH WAS BLACK BUT IT STILL DOSN'T WORK... I THINK IT COULD BE THE WIRE AS THE OTHER LIGHTS ON THAT SIDE WORK FINE. HOW CAN I FIX IT? MOT DUE IN A FEW DAYS. ALSO MY BOOT WONT STAY OPEN ITS VERY HEAVY WHEN LIFTING IT ! IS THERE ANYTHING I CAN DO TO FIX IT?
THANK YOU IN ADVANCE
If your boot lid is the normal hatch then it could be one or both gas struts are gone. One or both would need to be replaced. As for the bulb. Does the front side/parking light work. If not it could be a fuse. If it is just the rear light it could be a bad connection. Someone on here will know!
im really sorry for the uppercase... oh thank you.. gas struts ill look in to that. im not sure if the old thing will even pass the mot with the things that are wrong. thank you pete :biggrin:
I just got some boot struts from here - https://www.sgs-engineering.com/
Cheaper than Toyota ones but still feel pretty good; Instructions on the same site - Dead easy to fit! Although it's easier if you have someone to hold the boot up while you change them so it doesn't fall on your head!
I've fitted them on my own. Good idea to support to hold up the lid with a broomstick!
